Clutch Change Question
Discussion in 'The Garage' started by jc71355, Nov 17, 2002.
  1. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I'm changing the clutch in my 72 K-5 with Sm-465. I've decided to go with the Centerforce II clutch but what else Do I need to get and change while I'm in there?
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I would recommend you change the clutch disc, pressure plate, throw-out bearing, and the rear main seal while you are in there. Also, it would be a good idea to take the flywheel in and have it resurfaced.
    If your oil pan gasket is leaking at all, now would be a good time to change that too (while you have the extra room from the tranni being out).
    Thomas.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    throw out bearing, resurface flywheel, and check the pilot bushing.
  4. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    What about the clutch fork? I see that jegs has a "high performance one" since i'm going with an aftermarket clutch with more holding power should i go with a better clutch fork? or just replace the one in there or just leave it be?
  5. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Just inspect the clutch fork...mine was fine and I am reusing it with a higher performance three prong style clutch with no problems....I think you'll be impressed with the feel of a new clutch period if you haven't had one in the truck since you owned it.... night and day difference!
  6. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Thanks, Yea I'm hoping it will make some difference. Right now I have about 1.5" of pedal that actually does anything. It's a real pain to drive. I'm deffinately looking forward to the results.
