Clutch fan with spacer?
Discussion in 'The Garage' started by AZ_Overdrive, May 25, 2005.
  1. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    A quick question here.
    I upgraded the 89' Burb to the 4core radiator swap (454 shroud) and now the fan blades are about a 1/4 inch from the shroud.
    So, my question is, if I put a 1" spacer on the clutch fan to get it tucked nice and neat inside the shroud will that cause any problmes with the thermal clutch?
    The spacer is made of allum. I wouldn't think so but I just wanted to be sure.
    Thanks for any help!
  2. mrk5
    Apr 20, 2004
    12,346
    1,049
    Northern Colorado
    That's how my setup is. Been like that for a year now, probably 5000miles, and I haven't had any problems pop-up yet.
  3. AZ_Overdrive
    Dec 18, 2002
    117
    Arizona
    mrk5,
    Thanks for the info. I will go with the spacer and see how it works out.
  4. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    not more than 1 inch!
    I tried using a 2" spacer with a clutch fan--it caused the water pump shaft to snap flush with the case of the pump when I got my truck stuck in a snowbank,and had to race the motor up a bit to rock it out,sending the fan into the radiator and hoses! :mad: ...I'd say 1 inch spacer might be ok,but 2"--dont do it!...there is a lot of weight to a fan clutch and blade assembly,and they dont like being too far away from the mounting flange on the water pump,or they will start wobbling,and that leads to disaster... :crazy:
  5. 4XSlave
    4XSlave Registered Member
    Apr 30, 2005
    32
    Phoenix, AZ
    Eliminate the need for spacer and shroud by installing an electric fan. I got one with two 10 or 12" fans from summit and it helped drop the temp on my 83 fullsize.
  6. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    clutch fan is heavy unit. and the fan blades are to be about flush with the shroud. this is with themm all the way in the shroud. keep a eye on the setup with the spacer. radiators arnt cheep anymore.
