Clutch fans
Discussion in 'The Garage' started by Muddytazz, Dec 13, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I haven't had time to look at them yet, but I've got a 7 blade with a bad clutch and a 6 blade with a HD clutch, can I take the 7 blade fan off the bad clutch and bolt it to the 6 blade HD clutch?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I believe you can.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I believe they are physicall interchangable. But if you look in the parts books, there are different ones sized for different engines, fans, etc, transmissions etc. It's a judgement call.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I know my 7 bladed fan came stock on my 350/350/203 and the 6 bladed HD came stock on a 400/350/203
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Are they semi-rigid , or rigid ?
    I used a rigid from another truck thinking I'd get better airflow at all speeds , and ended up rubbing the fan shroud when flexed . Put my original semi-rigid back on and it doesn't rub anymore .
    They looked by eye to be the same diameter , and same depth , but was off enough to annoy me .
    I believe the rigid was 7 blade , and the semi-rigid was 6 blade . I would have to go home and look .
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I know my original 7 bladed one stuck out from the motor slight closer to the rad than the 6 bladed one I have on there now.....but I just like the fact of having 7 blades versus 6 blades, thats why I was wondering if I could just swap the blades over.
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Does anyone know if there are part numbers stamped on the fans and the clutches to do some research?
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The factory original should have a couple of letters printed on it somewhere. They signify how the internals work (when it locks, how long it stays locked, etc.)
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I was reading somewhere that you shouldn't put a regular duty fan blade on a severe duty or heavy duty clutch due to the fan pitch? How do I tell what is what?
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    You probably need to check out a Delco parts book to decode which one you have. :(
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Well that bites the big one lol
