Clutch Free Play?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Logan, Mar 7, 2001.
  1. Logan
    Logan Registered Member
    93
    Fournier, Ontario, Canada
    If got an '84 Fullsize Jimmy with the SM465 -- I just had the clutch replaced, and the pedal seems to travel about 4 inches down before it actually starts disengaging the clutch. There aren't any problems shifting, but 4" seems like a lot of free play. Is there an easy way to adjust this?
    I'd hate to find out I'm wrecking something when there's a simple fix.
    -Al.
  2. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Did you try adjusting the rod that goes between the z bar and the clutch arm? I have the same tranny in my '77 and there's a lot of play in every part of the linkage. Maybe the the new clutch is exaggertaing this play. I put roller blade wheel bearings in some of the pivot points.
    Take your yuppie SUV back home! I'm not going to pull you out again.
  3. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I adjusted my clutch just yesterday.......I've got a 79 with the SM465 and I'm not sure when chevy started using the hydrolic setup. What you want to do is to thread the adjustment nut/pivot towards the front of the truck. This is accomplished much easier if both springs are removed first....adjust the nut.....then reinstall the springs or better yet replace the long clutch return spring. Its the one that goes between the frame and clutch fork. Good luck. Its easier than it sounds.
    Any questions just ask
    James
    79jimmy@sprint.ca
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The adjustment is VERY simple - turn a nut on the bolt between the z-bar and the clutch fork. If I remember correctly, there is supposed to be approx 1/2" play before you feel resistance - hardly any at all. 4" is way too much.
    -- Mikje
