clutch going out?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mico85K5, Oct 19, 2001.
  1. mico85K5
    mico85K5 Registered Member
    46
    Wheat Ridge, Colorado
    My clutch is getting very difficult to shift (the pedal feels too easy to push - and this stick is nearly impossible to shift and it grinds). I am wondering if my fluid my be low? Is this jus the same container as the brake fluid, or do I need to get underneath in order to refill it? Or, is my clutch just gone?
    Driving your blazer=FUN!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Check the fluid in the tranny.... You will have to crawl underneath.... Also it wouldn't be a bad I dea to check the little resivor(sp?) on the firewall for the hyd. clutch fluid...
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Does the problem change when the vehicle is cold, or when it gets warmed up?
    If it's a hydraulic clutch, then definitely check the fluid.
    If it's a manual clutch, you can try tightening the cable.
    If all that fails, the throwout bearing could be shot; in that case, yes, it is time for a new clutch.
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  4. mico85K5
    46
    yes, only when the truck is cold it is very difficult to shift?
  5. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Your fluid level is low.
    I believe it takes DOT3 brake fluid, but you may want to get confirmation on that before adding it.
    Thomas.
