Clutch going south?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Aug 28, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Its not stuck in gear like I am used to...its a sm465 with the manual linkage. No idea on the age of the clutch but after this weekend's wheeling trip it has tons of slippage. I can't increase RPM's over about 500 at a time without it slipping. I tightened the luinkage to the tightest its ever been since I have owned the truck and yet it still slips....is it on its way out? Or just still adjusted improperly?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    sounds like it's leaving you!! I have a tranny jack if you wanna come and get it??
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    After wheeling when mine would slip it was because it was full of mud. Go to a pressure washer and stick the wand in by the starter let it rip and see what comes out. If it still slips after that it is time to replace.
  4. BowtieBlazer
    Jul 15, 2001
    2,462
    I'll try that on my way home friday...for now its staying parked...can't afford to actually burn it out if its not already burnt out because of it slipping so bad right now. Gotta limp it home 67 miles...
  5. BowtieBlazer
    Jul 15, 2001
    2,462
    I got one as well... /forums/images/icons/smile.gif Learned that from changing out the throwout bearing. Now I have learned I should have changed the clutch and all while I was in there...not looking forward to dropping everything down again to change the clutch out....
  6. Grim-Reaper
    7,385
    Atlanta
    When you take it to the coin wash and take the inspection plate off and have somebody hold the clutch down. THe dirt is between the clutch and the fly wheel and pressure plate. If you don't disengage the clutch then it will stay trapped in there.
  7. dogman
    dogman 1/2 ton status
    Oct 31, 2001
    213
    California, Santa Clara Co.
    make sure your shorting the ajustment rod to the fork.
    if you still slip its time for a clutch.
    don't buy the diaphragm type.
    three finger is the way to go.
    Buy a matched set with the disc, spring plate and Throwout bearing.
    don't mix parts, buy it as a kit all together.
    put a new pilot bushing in the crank.
    check out your fork right away, and have the flywheel turned.
    I pull the tranny with the T-cast on with the front driveshaft on the T-case.
    seperate at the back of the bell, the four big bolts.
    leave the crossmember attached to the tranny.
    I take the seat out and the floor access plate removed to get the bell housing bolts out.
    <font color="orange">dogman </font color> /forums/images/icons/tongue.gif
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    What about the exhaust crossover pipe.... Kinda have to unbolt and remove the whole exhaust system to get it out of the way.....
  9. dogman
    Oct 31, 2001
    213
    bummer, exhaust is in the way./forums/images/icons/frown.gif
    my 77'Truck has factory dual exhaust , its above the crossmember with no crossover.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I disagree on the three finger clutch comment. I have a diaphram clutch and it's the only way to fly.
  11. BowtieBlazer
    Jul 15, 2001
    2,462
    I was starting to wonder... I don't have the big bucks to dump into this thing right now! Hoping a new clutch can atleast last me a yr or two without any major dumping of the clutch.
    Any recommended brands out there?
  12. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Go to NAPA and get a LUK heavy Duty clutch for a little over $110 or so...Good clutch and it will last a while...LUK actually makes all the Centerforce prussure plates (not sure about the clutch disc?) But that should work well for you...As usual, always remember a new TO bearing and pilot bushing... /forums/images/icons/wink.gif
  13. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I agree, the diaphragm clutch can have equal or greater clamping force with lighter pedal feel than the Borg &amp; Beck (three finger). It is a superior design IMO.
  14. dogman
    Oct 31, 2001
    213
    /forums/images/icons/smile.gifOk with your choice. I'v done every clutch change on my 77K10 rig. I bought it New. When I use it to pull a trailer through 8 miles of sand. I will only Install the Heavy Duty 3 finger. Been there, /forums/images/icons/mad.gif done it&gt;&gt; Diaphrams are for 2 wheelers and Birth Control. /forums/images/icons/grin.gif
