Clutch help quick
Discussion in 'The Garage' started by chris12, Oct 28, 2006.
  1. chris12
    chris12 1/2 ton status
    Apr 23, 2006
    267
    Forest Ontario, 1/4 hr from Port Huron Michigan
    OK just took the clutch off and ready to install the new one but does a bearing or a bushing go in the flywheel. The clutch came with both and when i removed the old one nothing was in the flywheel hole.
    The truck is a 88 k-5 350 with a Sm 345 12' clutch
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    run the bushing. they are more reliable then the bearing. ive heard of a few people having the bearing fail...
  3. chris12
    Apr 23, 2006
    267
    alright so ill run the bushing instead of the bearing.
  4. chris12
    Apr 23, 2006
    267
    Also all of the bolts holding the clutch on had flat washers, the new clutch says not to use flat washers or lock washers. IS this normal.​
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Yep. It'snormal. I can't remember the last time I used washers. A little locktite and your all set.
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    slip that bushing over the input shaft of the trans to make sure it fits first. That's something you want to find out now rather than while trying to install the trans.
