Clutch hydro line Question?
Discussion in 'The Garage' started by RingMaster4x4, Feb 9, 2005.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Can anyone tell me the size of the nuts and the steel line that is used for a 1985 Chevy truck hydro line that runs from the master cylinder to the slave? I need to make a custom line but I can't find out this info. TIA.
  2. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    TTT Anyone? Can any one point me to where I might find the info?:confused:
  4. dyeager535
    26,979
    I feel bad for you, not at home to look at what I have.
    The only thing I can suggest is calling Napa or someone similar, and going down and looking at what they have for stock stuff. They should have the master, slave and line on hand.
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I tried every where but NAPA. I took it to ever place in the 3 towns that are around me and came up with nothing. I will try them but I am not going to get my hopes up.:frown1:
  6. dyeager535
    26,979
    I guess I'm kind of spoiled I've got a Napa distribution center near me, so just about anything Napa carries they have. They even have rebuild kits for the masters and slaves. Good luck.
  7. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I will get you the info on the one I'm using on my K20 as soon as I get home tonight. It is still off the truck so it will be easy to get the info. My setup is off an 89 1 ton 2wd old body style so I would be pretty confident it will be the same as an 84.
  8. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    That is ok my dad and I have found a way around it. My dad took it to a welding shop that said that it was 6MM line and that they could take a 1/4 in. line and swell it to fit over it. Then weld it up.:grin:
  9. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Glad it worked for ya. Measured before I saw your post. The fittings on mine are for a 1/2" wrench and the metal line is 1/4" od and has some 1/2" od rubber line.
