Clutch Linkage Woes
Discussion in 'The Garage' started by Green71, Jan 24, 2003.
  1. Green71
    Green71 Registered Member
    May 29, 2002
    26
    St. Clair, MI
    Did GM offer mechanical clutches for the newer body style? I went to the dealer (morons) and they kind looked at me wierd /forums/images/graemlins/eek.gif. They have no idea what theyre doing. i want to swap the sm465 int my dads 95 2dr YUKON, (its an automatic) and he wants mechanical linkage. if they didnt offer the mechanical inkage, i was thinking i could maybe use the linkage from the older body style. if i do that, would i have to use the pedal too, or could i use the pedal from the newer body style? i kinda want stuff to look matching. /forums/images/graemlins/crazy.gif i dont think the frame widths changed, but i may be crazzy. Please help me! thanks for all your help guys! i have learned alot from all of you. you guys rock! /forums/images/graemlins/grin.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    If you tried, I bet you could post this in more than the three forums that I found it in. /forums/images/graemlins/tongue.gif
  3. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    As far as I know, GM did away with mechanical linkage about the same time they went to hydraulic clutches in the early '80's. The firewall and underdash sheetmetal of the '95 Yukon is shaped differently than the earlier K5's, so I doubt that any mechanical (or hydro) pedal assembly will bolt in. I think the frames are entirely different also. To convert your '95 Yukon to mech clutch will be entirely custom work, that's why the dealer looked at you weird. Also, most people prefer the hydro setup, not mechanical, for ease of pedal pressure and no linkage binding.
