Clutch master cylinder mounting.
Discussion in 'The Garage' started by BowtieRed, Sep 17, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    I got lucky- there was a crusie control line running through a hole the perct location and size for my clutch master cylinder. Now- what is the easier way to mark the holes to drill so i can drill them from the opposite side? Also, can i use a couple washers under the maser and the firewall because the pedal bracket limits my clutch pedal travel necessary by about ¼" also it'll sit flatter on the firewall that way
    Thanks,
    Red
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    NOBODY KNOWS!??!
    doesn't matter now, i'm done anyway, no washers.
    How do i bleed the system??
