Clutch Options
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confedneck79K30, Oct 14, 2006.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    Ok guys and gals i have a clutch question... my 79k30 is manual sm465
    when its built (which may be a while) and ready to run around and use, i want to be able to pull a sled at the local sled pulls with it, will a LUK Progold hold up to this task? or do i need to go heavier?
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Just from personal experience,I'd go with Centerforce on this one.
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    centerforce do they last a long time or are they super tough? a tranny shop i service said i should look into zoom, but when he said it could run 800 bucks i almost died..
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    While I don't have much experiece with Zoom's drag clucthes, their regular stuff ($200-$300) is junk. I've had 2 go belly up within 1000mi.
    I'd agree with the others, the Centerforce Dual Friction would be my choice, I've yet to make one slip.
    Also note that Centerforce Clutch discs are made by Luk, in most cases. If you look at the stamp on the disc, there's a litle 'Luk' stamp.
    I've not tried any of their new DFX clutches, I've always been happy with the dual friction version though.
  5. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    why go centerforce then, why not just buy a LUK?
  6. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    When I needed a clutch for my 95 K2500 with a NV4500, I called dial-a-clutch. I exaggerated and told them I ran a built 406 and towed 8K regularly and 10K occasionally, and the salesperson told me that a pro-gold would be overkill for my application and that a standard LUK repset would be fine. I think that a Pro-gold would work just fine for your app. The LUK is also quite a bit cheaper than the CF, at least it was for my app.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The centerforce has an advantage with the weights that help lock it stronger the faster your engine revs, that is why it's better.
    Hence the name :D ( from centrifugal forces )
  8. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    well thanks for all your help guys, i feel pretty confident that ill go with a progold, unless i decide to go with a new project.... 95 s10 blazer 4 door 1 ton... 4.3/465/205/maybeablower??
