Clutch Pedal Bracket
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JonV, Mar 17, 2003.
  1. JonV
    JonV Registered Member
    Mar 17, 2003
    27
    Hesperia, CA
    I am rebuilding the clutch pedal bushings and sleeves on my 79 Jimmy. Anyone know any sources for a new bracket?
    Thanx
    JonV
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No, but when you find out, I need to know too. My pedal is all messed up.
  3. JonV
    Mar 17, 2003
    27
    Hesperia, CA
    We got it all apart. The sleeve that's in the end of the pedal is all worn. Anyone know where to get a new one?
    Jon V /forums/images/graemlins/k5.gif /forums/images/graemlins/1zhelp.gif
  4. dyeager535
    26,975
    You talking about the nylon(?) bushing that it pivots on? My dad went to the wrecking yard, took apart a couple of "low" mileage brake pedals out of GM cars of 80's vintage, and robbed their bushings. Added one or two as I recall, to better support the shaft, apparently he thought it was kind of a cheap way for GM to go with only one or two bushings.
    Anyways, your local GM dealer should be able to dig that part number/part up for you, and it shouldn't cost too much.
    If they won't help you, re-post here, I should be able to dig that number up, as long as its the same as an '85/86 truck part.
  5. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    I got the bushings at GM for like a Buck each.
    -Ben
  6. JonV
    Mar 17, 2003
    27
    Hesperia, CA
    OK! Got it figured out. My clutch pedal pivot arm is worn out. It's the arm that the clutch pedal arm bolts to. It has a fixed sleeve at the top, that is worn out, because someone put too strong a spring on it and had it going at an angle. I have the steel sleeve that goes inside this fixed sleeve, and the nylon bushings are what holds this floating sleeve in. I just ordered a new pivot arm from Friesen Chevrolet in Nebraska. Talk to Bill in parts. 800-525-1691 ext 538. Totally helpful. He even faxed me the blow up diagram. They specialize in old obselete parts. I got all the parts I needed from him. Nylon bushings, steel sleeve, pivot arm, rubber boots for push rod, return spring and rubber bump stop. Very helpful. Now to put it together.
    Jon V /forums/images/graemlins/k5.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/cool.gif
