Clutch pedal placement in tranny swap??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BMR, Mar 30, 2002.
  1. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    I know a many of you have done the 700r to a sm465 swap, so i am asking for any helpful advice about the bolting up the clutch pedal assembly in the truck? I got the pedal assembly out of a 88 K1500 which is different than the blazers but it should still work, no? Did you have to fab anything to bolt it up in the dash? Anything would help.
  2. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    What year is your rig?When I swapped mine I used a pedal assembly from a 77 Sub.It bolted right in.I also used the subs column so I don't have the auto shifter handle.Not sure if the 88 will work.Will most likely need to modify it a bit.Maybee alot.
  3. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    It's a 85'. There is no brakets in that column that i can bolt up to. Would it be easier if i replaced the steering column with all the brackets all together? Or did i not get a bracket when they pulled out the clutch pedals for me? Sh*t it should be this difficult, I think i am just making this harder than it really is. I thought that the 88 pedal assembly would work fine.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    isnt 88 an entirely different animal then your 85
    stick with same body style
    drop the column and swap pedal bracket
    I had no snags
  5. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    So the brackets are different??......Well that changes everything.....I went through about 25 trucks at this yard and not one hydo. setup for a Blazer, they where all K1500!! I rolled the dice....and lost....i think i will hunt some more...I really didn't think that there was that much of a difference.
  6. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    I modified my pedal bracket with a sawzall and just added the clutch pedal to the left of the brake pedal. I have done this with two trucks and it has worked out well. Most recently on an 85 K5. Good luck.
  7. dyeager535
    26,982
    191
    I don't think it would be hard (not nearly as hard as retrofitting '88 pedals) to make a pre-hydraulic (starting in '73) pedal setup work. At worst, you would have to add the stud for the master cylinder plunger, at best, they are in the same spot.
  8. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    Well yesterday I went out and got the right assembly. There is a big difference. The assembly i just got now is a one piece unit with the brake and clutch out of a 85' 2500 GMC, The "old" clutch bracket I was fighting with out of the 88' the clutch and brake pedals were seperate. I could make it work but since i found the bolt in one for my turck I'm going with that.
    Thanx for all the input.
