clutch pedal
Discussion in 'The Garage' started by chebbykrawler, Jun 22, 2006.
  1. chebbykrawler
    chebbykrawler Registered Member
    Feb 6, 2005
    10
    nevada
    i cant figure out how to get the clutch pedal out of my parts truck, anybody have any tricks on getting it out. any help is appreciated
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    the complet hanger and pedels are drop out when the brake booster is unbolted and two bolt/or nuts in under colom are removed. if i recall correctly.
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Are you swapping in a stick?
    If you are then, :bow: :waytogo: :saweet:
  4. chebbykrawler
    Feb 6, 2005
    10
    nevada
    yes i am swaping in a sm465 in place of the 700r4, so ur tellin me instead of tryin to separate the clutch pedal from the hangar, i should just take the whole assembaly out of the parts truck and install it in the blazer. any help is appreciated
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    yes take the entire assembly out of your truck....
    drop the steering column with the 2 nuts that hold it up... then unbolt the brake booster... 6 bolts.... your should shimmy out of its place.. pain in the arse to get out but just take your time...
    then the new one goes in the same way...
    hey also are you doing the hydro clutch setup? if not that big spring on the mechanical is a PITA to do....:haha:
  6. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    Great tech guys! I'm going to use this info.
