clutch problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Project, Jun 6, 2003.
  1. Project
    Project Registered Member
    Nov 6, 2002
    30
    rock hill, sc
    hey folks,
    i have a toyota truck with chevy driveline(350/sm465/np205).
    i'm having a problem with the clutch, master cylinder and slave cylinder are chevy (both brand new)but i cant get enough movement to push the clutch fork back.
    first question: how far does it need to go! it's gotta go all the way back or just 1.5" or whatever.
    second question: if it doesn't have to go all the way back, what should i look for to fix?(you think i put the disk backward or ?????)
    i appreciate any help in advance.
  2. Project
    Nov 6, 2002
    30
    rock hill, sc
    /forums/images/graemlins/confused.gif /forums/images/graemlins/thinking.gif
  3. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    1. Do you get any movement off the throw out fork?
    2. How much pedal movement do you get/have. Mine moved quit a bit before it starts to move the fork.
    3. Is this something that just happened, or has it been that way since you installed the new MS and SC?
  4. Project
    Nov 6, 2002
    30
    rock hill, sc
    i'm gettin like 1.1/4" movement from the fork.pedal has no free movement, as soon as pushing it moves the fork and yes i just instaled the MC and SC and i haven't driven it yet.(0 miles on everything)
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    They can be a PITA to bleed. Make sure they are completely bled.
  6. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Forget it and get some skinny tires
  7. Project
    Nov 6, 2002
    30
    rock hill, sc
    there is no air in lines, i used a power bleeder. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  8. Muley
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Even still a pwer bleeding can leave air in down at the SC. Here is what I suggest. Bleed the SC by pushing the piston rod in while you open the bleeder screw. The trick is getting the screw closed again before it bottoms out. Do this 3 or 4 times and then see how it feels. My GM mechanic buddy says the air in the lines likes to sit down there at the SC.
    Otherwise I am think that you do have enough pedal movement required to push the throw out fork. It sems like I have about 6 inches of pedal travel before it bottoms out on the floor.
    That is all I can think of right now.
  9. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Umm did you just convert this from a clutch linkage to a Hydro clutch???
    If so, the forks are DIFFERENT!!! /forums/images/graemlins/ignore.gif
  10. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    are you using the pedal from the toyotsa or are you using a chevy pedal that you swapped in...If you are using a stock Toyota clutch pedal, it is possible that you may have to move the MC pushrod mounting location down the pedal a bit to get more piston travel at a given amount of pedal travel...
    Chris
