clutch problem
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Project, Jun 7, 2003.
  1. Project
    Project Registered Member
    Nov 6, 2002
    30
    rock hill, sc
    hey folks,
    i have a toyota truck with chevy driveline(350/sm465/np205).
    i'm having a problem with the clutch, master cylinder and slave cylinder are chevy (both brand new)but i cant get enough movement to push the clutch fork back.
    first question: how far does it need to go! it's gotta go all the way back or just 1.5" or whatever.
    second question: if it doesn't have to go all the way back, what should i look for to fix?(you think i put the disk backward or ?????)
    i appreciate any help in advance.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Slave Cyl. with a longer stroke. /forums/images/graemlins/grin.gif
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    what do you mean by [ QUOTE ]
    hydro setups are not very forgiving. they are preset from factory, so make sure your master is going all the way in or very close to it.
    did you bleed it?? i had to pump mine line 100 times before it had the push to open up the clutch.
    also, is the clutch fork the correct one?? it should be strait with no curves or bends in it.
    ARQ.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've heard that some slave cylinders don't have the bleeder on the top and that you have to remove it to bleed it correctly. Does the bleeder point straight up?
