Clutch Question - HELP!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by IGOR, May 23, 2000.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Hey guys (& gals)
    Correct me if I'm wrong, but if a clutch pedal goes all the way to the floor and doesn't come up - it's usually a sign of the clutch "going out" - this means the clutch disc is worn out or what? My buddy called me - he has a c10 '76 long bed PU, with a 3speed on the tree that the problem is in-
    Also, what are the necessary parts, and about how much will they cost?
  2. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    The clutch disk may be wrong, but I would think more along the lines of a bad return spring or bad pressure plate....and also I have seen throw out bearings seize up and eat through a pressure plate....
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
