clutch question on swapping from a 350 to a 400
Discussion in 'The Garage' started by 55Willy, Mar 31, 2006.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm trying to put a 400 sbc in my 68 burb all the clutches I have found for a 79 van (what the 400 came out of ) is listing the wrong spline counts for the sm465 that the burb has. can I just use my set up off of my 350 minus the flywheel since the 400 is external balanced. I got the new flywheel coming.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    as long as the bolt holes on the flywheel match up, yes you can. The only difference between the two is the flywheel.
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    sweet thanks man.
  4. goldwing2000
    goldwing2000 Guest
    And the harmonic balancer.
    But that should already be on the engine.
