Clutch ?s
Discussion in 'The Garage' started by dragoonranch, Nov 8, 2006.
  1. dragoonranch
    dragoonranch Registered Member
    Apr 22, 2006
    34
    Rosebud, Tx. / Baghdad, Iraq
    On my 78 350/465, I have an 11 inch clutch, will the 12 inch fit on the same flywheel or would it have to be changed?
    Is there much of a difference between these two clutches?
  2. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    it should fit i put a 12 inch clutch in my truck that had an 11 incher
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It'll fit. No problem. Makre sure you get the pressure plate that goes with that clutch though.
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    wouldn't there be issues of the flywheel only being worn in the area that the 11" made contact with?
  5. dragoonranch
    Apr 22, 2006
    34
    didn't think of that, guess I could get it turnded down
  6. diesel4me
    Jul 24, 2003
    17,561
    940
    Massachussetts
    one thing..
    I had no luck getting a 3 finger 12" pressure plate to clear a "full" aluminum bellhousing a few times,it was too big and rubbed on the bellhousing....ended up going with an 11" diaphram style clutch instead..which is plenty beefy enough anyway,especially if its a "centerforce" design..
    I never tried using a 12" diaphram style pressure plate with the full aluminum bell housing,it might just fit...I'd definately have the flywheel re-surfaced regardless of what size you put in,its not worth doing the job if you dont do it 100%--it'll come back and bite you in the butt!..:crazy:
  7. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Flywheel resurfaced is a given. Always a must.
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    not for this redneck... :haha:
  9. dragoonranch
    Apr 22, 2006
    34
    Well, we shall see soon enough, the dual action centerforce 12" hsould be at the shop soon enough.
  10. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I've put the Centerforce dual friction 12" on my 1973 SM465 350engine.
    Fit no problem.
  11. cj7jeep81
    cj7jeep81 1/2 ton status
    Feb 17, 2003
    110
    Indiana
    i'm running a 12" luk clutch in mine. i believe the bellhousing is out of a '79.
  12. dragoonranch
    Apr 22, 2006
    34
    I am switching to a hydro clutch w/ a Novak kit, so we are replacing the clutch while it is apart replacing the fork. this truck was auto, and PO did a half ass job on the swap so the linkage is janky at best. You have to stand on the clutch pedal pretty hard to work it, and on the rocks it wears you out. I appreciate yalls input on all of this.
  13. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Huh...never knew :dunno:
  14. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hey now, there's nothing janky about a metro. :mad: :p:
    Mark down another one for having a 12" clutch. I've got a 12" luk pro gold in my crew cab behind the 454. It's an 84 with the aluminum bell housing, diaphram style fit no problem.
    In regards to switching to hydro, did you see that "tech article" that supersize75K5 did? Seems like a good way to go, using cheap off the shelf stuff. Don't even have to drop the tranny (even though you are already).
  15. dragoonranch
    Apr 22, 2006
    34
    I might have, but will go back and check it out.
  16. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    im also runnin the 12" luk pro gold diaphragm clutch. so far it has been super smooth, no problems.
  17. bronc3buster842001
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    i ran a 12'' clutch from autozone in my 78 it fit without a prob
