clutch safty switch ?
Discussion in 'The Garage' started by sweetk30, Nov 25, 2006.
  1. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    i found a hydro pedel setup and swaped it in my truck with the other parts. i didnt see a safty switch on the pedel assembely. is there suposta be one or not?
    i have converted this auto cab to stick and have the reverse lights figured out easy just plug in to the stick tranny plug. just couldnt figure out the park / nutral safty end of it.
    pics would be great if you have anything to offer.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The neutral safety switch is at the pedal. It is a bit of a safety issue.
    It is by sheer luck that I only sustained massive bruising instead of a multi-break leg injury due to the lack of such a safety switch. :eek1:
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    The neutral safety is mounted to the steering column right before the firewall on the inside. Its a two pronged plug (the only one in that area). Go to the junkyard and get a switch with the pig tail, unplug the neutral safety and splice the new pigtail onto those wires, plug in the clutch switch and your good.
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    so you guys run one?
  5. sweetk30
    Nov 1, 2004
    25,539
    538
    yes on a auto colum. not on a stick colum as i have 2 now and both dont have them. i need some info on the pedel side of the problem.
  6. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    You should still have the picktail hanging from the wireing harness toward the bottom of the column. You can tell it's the right plug when you get 12 volts to one side of it when you have it in the start position. Once you have that just get the switch and pigtail from a junkyard and you'll see where it mounts on the peddle assy.
  7. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I disabled the switch on mine. I actually like being able to crank the motor in gear, and being able to start the motor without climbing into the truck, all just personnel reasons of course.
  8. sweetk30
    Nov 1, 2004
    25,539
    538
    :surepal: thanks but you need to re read my #1 post slower. i DONT have the switch on the pedal assembely:doah: and its hard as he!! to find hydro parts. so i need pics or some other info to add the switch.:1zhelp: and i know were the wire is in the stock harnness.
  9. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I also disabled mine because all to often on steep ground it is imposible to operate the clutch, brake and gas all at the same time. just my .02.
  10. sweetk30
    Nov 1, 2004
    25,539
    538
    i do plan on a bye pass switch for just such a time. kind of like the toyotas have.
