Clutch Slave Cylinder - Bleeder & Hose Mixed Up...
Discussion in 'The Garage' started by Impex, Aug 18, 2003.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    Doing the hydro clutch conversion:
    Old one that i got has the bleeder on top.
    old one with bleeder on top
    Instructions sheet that came with new one has the bleeder on top.
    Instructions with bleeder on top.
    New one from www.gmpartsdirect.com with bleeder on side with hose going in on top.
    New one with bleeder on side and hose from top.
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    so which way does it go??
  2. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    The bleeder should go on the top, you will never get the air out if not, can you switch the bleeder and the hose ports around like your old one? Someone could have put the bleeder in the wrong hole.
  3. Impex
    469
    Chandler, AZ
    ya i can switch them around.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I could never get it to bleed in place anyway
    had to pull the slave and hold it at an angle
  5. Impex
    469
    Chandler, AZ
    MJ: im sure if i search i would find out but while were on the topic /forums/images/graemlins/tongue.gif do i just bleed it like i would a brake caliper? & you found it best to hold the slave in your hand, rather then mounted to the bellhousing?
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yup like a brake cylinder only easier
    so i read instructions
    they say to unbolt it and hold at angle
    makes it slightly easier to reach both the pedal and the bleeder while bleeding alone /forums/images/graemlins/smile.gif
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    my SC I got from GMPD was the same way...I just swapped the bleeder and the hose and have had no problems for over a year now..
    Soimebody probably messed it up at the assembly plant...
    Chris
