Clutch Slave Cylinder Rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eshorvath, Aug 14, 2003.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Has anyone rebuilt the Clutch Slave Cylinder? Anything special needed? Any comments?
    Eddie
    How about the Master Cylinder? /forums/images/graemlins/ears.gif
  2. dyeager535
    26,980
    Last time I checked, one or the other was reasonable to buy new/remanufactured, the other was insanely expensive when I checked.
    Ask NAPA or someone like that, if there are even rebuild kits for both available. You'll need to hone the cylinder(s) to do it right.
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Either rebuild both and or replace both at the same time and bleed out all the crappy fluid. No matter how bad it is or how expensive it is be glad you don't have a Ford Ranger. Their slave cylinder is in the bell housing, you have to pull the trans to replace it. what a stupid design. /forums/images/graemlins/eek.gif
  4. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Called an internal slave...Many newer cars have them!! They are a pain!
