Clutch System Bleeding- Perfected READ if you have HYDRO CLUTCH!
Discussion in 'The Garage' started by BowtieRed, Oct 11, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Definitely the easiest way, without a doubt!
    If everything is off the truck-
    1: put master so the fitting going to the slave is in a cup of brake fluid, pump a few times at different angles until no more bubbles.
    2: take off all fittings on slave- put both in cup of brake fluid- use screwdriver to pump until no more bubbles
    3: put everything on truck, fill resevoir
    4: pump slave cylinder from under truck until no more bubbles (2-5 pumps)
    With this method the bleeder screw is never used, but it works perfectly, and takes maybe 5 minutes TOTAL, if you put the line to the master cylinder on BEFORE you put it in the truck, it will save you headache!
    I never found this method when i started, but it may be out there. . . here is the Henry Method /forums/images/graemlins/laugh.gif
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    sounds like a winner /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
