Clutch system bleeding.
Discussion in 'The Garage' started by BowtieRed, Sep 17, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Yeah, uh, instructions? /forums/images/graemlins/grin.gif
    Thanks,
    Red
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Open bleeder, step on clutch, close.
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i don't need to bench bleed the master do i?? /forums/images/graemlins/eek.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Dunno, never had one go that dry. I doubt it.
  5. swampblazer
    swampblazer Registered Member
    Mar 31, 2003
    49
    mass, u.s.
    i just replaced one in a fullsize over the weekend for a buddy. you install everything dry. (if replacing the lines slave and master. you do need to bench bleed the master. than you install everything, than open bleeder on slave and let it gravity bleed. that should be all it needs!
    peace
    luke
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok, i already got the master in, PLEASE don't tell me i have to take it out again! do i have to take the line off of it? i don't want to because just putting that line on what a huge bitch. i need to replace it though- it's rubbing the manifold /forums/images/graemlins/eek.gif
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I back bleed clutchs, pump the fluid through the slave cylinder untill the resevoir starts to fill. top off the resevoir and yer done.
    A Phenoix injector is nice but a regular brake fluid pump works too.
    That is by far the quickest method.
  8. dyeager535
    26,979
    I didn't bench bleed my master, and it works fine.
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i heard its a pain, i might be replaceing my Cluch slave valve thing, its all wet around it where it bolts to the bellhouseing, damn at 52$ for a new one. im gunna start soaking that bottom bolt at the slave valve just for fun so if i need to take it off it dosnt break off or somthing, but it does sound like a pain. /forums/images/graemlins/thinking.gif
  10. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    You can pressure bleed it. Get a chunk of bike innertube and put it around the fluid reservoir after you fill it. Crack the bleeder and pressurize the innertube with compressed air. Just dont run it out of fluid and it works great.
