Clutch & Tranny problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Josh, Jul 16, 2001.
  1. Josh
    Josh Registered Member
    Dec 11, 2000
    75
    Glendale, AZ
    This isn't for my Jimmy but it's still for a gm product and could be used on a Jimmy/K5. Anyway, I just rebuilt my transmission (Muncie M20) replaced the flywheel, clutch plate, pressure plate, throwout bearing and pilot bushing. I got it all back together and it makes a squeal sometimes. I haven't driven the car for fear of parts breakage, but here are the situations.
    Clutch out transmission in neutral - quiet
    Clutch in transmission in neutral - quiet
    Clutch in transmission in gear - VERY quiet squeal
    Releasing clutch in gear - squeal gets louder as pedal comes out.
    I think it's the pilot bushing, I don't remember putting any lube on it or the input shaft. The clutch seems to be engaging/releasing ok, as I can put the car in gear (engine stopped) and cannot push the car, but when I push in the clutch I can push the car. Anyone with ideas? Please help?!?!?!
    Josh
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would say you have a problem with your pilot bushing my friends truck did the same thing i replaced his pilot bushing and problem solved
    77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    made sure to regrease the release bearing...sounds like the symptoms of my throwout bear right before it went south...strange but true....
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
