Clutch Woes
Discussion in 'The Garage' started by TXsizeK5, Nov 3, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    only somtimes, i push in my clutch and it feels really really... (hard to descibe) but spongy. Its like isntead of being smooth, its real rough and its like it almost like the pedal and whatever its connected to is ribbed. Like when you pull it out it kinda has a real small rough spot, then a real quick smooth, then rough, then smooth, all the way out. And this only happens sometimes. Sorry if i cant describe it any better. Can anyone help or diagnose? thanks!
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    hydraulic or manual linkage?
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I am asumming a hydro b/c it's an 87...What does the fluid look like?if it is dirty, yo u may try bleeding/flushing the system and see what new DOT 3 will do...Could also be the pivot ball for the clutch fork..does you bell housing have a grease zerk on it? if so shoot a little grease in there...Because of the problem is intermitent, I would say it is the fluid or a bad MC or SC or both..I would start at the fluis and pivot ball and go from there...
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the 'new' part had me unsure.
    I was thinking if it is hydro you should look at the retainer that the throw out bearing rides on.
