Clutch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Nov 12, 2004.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I helped my pops put a new clutch in his 84 pickup. Now the pedel is hard to push in. What could be the problem. Already swaped out the Z bar. Thanks.
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    There are two basic styles of pressure plates out there. One is a diaphram clutch with many fingers for the throwout bearing to push on. This type of clutch has a fairly light pedal feel even with mechanical linkage. The other type is a 3 finger, or Borg & Beck. The B&B is a bit stronger...but also has a brutally stiff pedal feel to it.
    I suspect you replaced a diaphram clutch with a Borg & Beck.
    Rene
  3. 1-ton
    Apr 17, 2004
    2,884
    163
    Las Vegas, Nevada
    Did you put the throwout bearing in backwards?
  4. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    The clutch has many fingers. Good question on the throwout bearing. I put the bearing side toward the clutch and the fork behind the bearing in the groove.
