CMR stamping code, 350 engine
Discussion in 'The Garage' started by R72K5, Nov 2, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    with just a bototm end minus balancer and oil pan, how could i tell which of the following two are what the bottom end is, i picked one up a little while ago with this tamping code:
    1974 CMR 350 tur hydro trans. - 145 2 A
    1978 CMR 350 m/t L82 4 220 4 Vette/Z-28
    i looked up 78 vette info and found out that sequential unit numbers were 400,001-446,558 so if vin code on block is between them, then hmm.. http://100megsfree4.com/corvette/1970/vet78.htm
    thanks
  2. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    Check the back of the crank for a pilot bushing. It would be the vette engine IF it has the bushing in it.... I'm not sure but I think both might be machined for one...
    The L-82 had forged pistons, crank plus 4 bolt mains. I would assume that the other would have had cast pistons and crank.
    Let me know the vin my 78 L-82 no longer has the original engine.... Maybe its mine /forums/images/graemlins/thinking.gif No thanks I don't want it back
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its 2 bolt so hmm..
    oh well, i know it will run if i stick any head son it and i need a runnign sbc sooooooo., im gonna go get kerosene and flush it out and stick heads on it and a cam in it and run it, planning on in next coupel days to have it assembled
    thanks
