CO Emmisions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by colorado_emt, Mar 24, 2000.
  1. colorado_emt
    colorado_emt Registered Member
    Mar 12, 2000
    84
    Arvada,CO
    I have a '79 and want to go to dual exhust. I dont want to spend money on high flow cats. I want to know if i can get away with chucking the cats and still pass emmisions test.
    Thanx
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    If it came stock with cats (which I'm sure it did) then it's required in Colorado (front range only, mountains excluded). One time they failed me because my "Check Engine" light wouldn't come on in my GMC Typhoon.
    BTW-
    If you have headers, I have a dual exaust system thats like brand new.
    Shawn
    87 K5
    Littleton, CO
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Shawn, will that exhaust fit a 86?
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
  4. Rayven90
    Rayven90 Registered Member
    73
    FT Lupton, CO.
    If it came stock with a cat it must be installed to pass an emission test. I don't have this problem since I live 25 miles north of Denver....in Farm country....We are not yet required to have emissions.
    Ray
  5. getsome
    getsome 1/2 ton status
    107
    Colorado
    I had a 79 *eep that I put headers on after I rebuilt a 360 for it and what I found out it that if you have duel's you need two cats. I was working at a dealership in the peoples repubic of Boulder and I went through their emmisions book and found out what hardware was mandatory for it to pass the visual. My year *eep required a smog pump, air injection into the headers and two cats. I caught some greef from a e-test place about me mission a egr valve, but I just asked him if that was required and he shut up. Hope this helps a little bit.
    Getsome
  6. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    It depends on what county you're in.Weld county,for instance,doesn't require an e test.At least that's my understanding.Thats also where i'm gonna by my house,can you think of a better reason?
  7. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    If you live or work in Denver. You will need an e-test even if it is registerd in an exempt county. 1 of my bud's got popped for working in Denver while his truck was registerd in Weld county. It also depends on the local Denver cop w/ nothing better to do than to look at E-stickers to see if they are expired.
    i_4x4
    LET'S ROCK
    Don't follow me you will get STUCK!!
  8. Shawn
    1,753
    5
    5280'
    What happened to your friend? A fine? How much? Just curious...
    Shawn
