CO2 OBA system recommendations?
Discussion in 'The Garage' started by dontoe, Jul 25, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    My wife said she'd get me one for my birthday. Is this one a good deal, and will it run air tools (my biggest requirement)? I want a fixed 150 PSI regulator, 20 LB bottle............what's yer input?
    SPORT SERIES HyperFLO2 Systems
    HyperFLO2 Source? systems include lightweight aluminum powder coated** tank, HyperFLO2 regulator, 20ft Comp-Flex hose, quick connects, tire chuck and EVEN the high quality, powder coated tank bracket.
    OA-2KIT20
    20# / 1280 gallons Complete system $309.00
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Surf E-bay, sometimes they go for wholesale. I got mine with 15 lbs. tank/10 lbs. capacity, with hose/coupler & bracket; I think it was $160+truck.:D
    I haven't/don't use it for air tools(yet). Its great for fill-up after a trail run with a crowd when local is only one gas station with one hose.
    I also use for spot pressure(garage) in between weekends, before topping it off before a run.
    With a blow gun, it can also serve as a back-up fire extinguisher.:D
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Piece it together. I have a total of $40 into my 20Lb Bottle and regulator.
    I have compared my reg to the PT one and it flows about the same and does not freeze, even after 15 minutes with a cut-off wheel at full speed.
  4. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Where did you find your regulator at?
  5. readymix
    May 30, 2004
    6,706
    26
    That is G-14 Classified.............:haha:
    I will look at one of them tonight and get the MFG and Part # off of it.
    I got 5 of them but 3 had ruptured diaphrams. Easy to get parts but I just never did it.
  6. readymix
    May 30, 2004
    6,706
    26
    Watts Fluidair
    R1011-02D
    That is the number as best as it can be read off of the lable.
    Only specs I could find for a R11 series is that the max SCFM is 100.........
    Doesn't quite sound right to me though. See if you can match that anywhere
