CO2 System
Discussion in 'The Garage' started by surpip, Nov 1, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Im lookin for plans, parts list, tips, tricks ,and anything else i might need to home brew my own co2 system. Thanks alot,
    dale
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Three words.....
    Local welding shop.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    are you looking for a adjustable reg??
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    no i dont think ill need that, but im not shure what pressure ill need to run the arb, reg., ill go and check out the welding supply store down the street from my house when i get back home
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    no i dont think ill need that...
    I think ya will /forums/images/graemlins/tongue.gif
    On a warm day my bottle can get up to 1200psi in it so a regulator is good /forums/images/graemlins/grin.gif When you go to the welding supply make sure you look at a high pressure regulator (one that goes over 100psi) because a low pressure one only goes to about 30psi max. or so.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    You can get the bottle in aluminum or steel. Advise aluminum. Ask about high flow vs. low flow bottle valves, both do exist. Advise high flow if filling tires or running air tools off the bottle.
    You do need a regulator, just a Q of if you want/need to be able to adjust the output pressure. If you're going to run an ARB off of it you'll want a dedicated regulator for that part of the system. Check Grainger or McMaster for those. A typical air pressure regulator should work for the ARB system once you've gone thru a regulator mounted on the bottle. Reason for a seperate reg for the ARRB is that you don't want to crank up the bottle reg to run something like an impact and then forget & feed the ARB system 200 psi. That would be bad.
  7. ugly
    ugly 1/2 ton status
    Aug 8, 2004
    157
    Denver
    aluminum 10# $80.00
    high flow high pressure regulator $70.00 (for quality)
    hoses and fittings $30.00
    mounting bracket $20.00
    co2 system $200.00 set up!
    Try beer system distributor or welding supply /forums/images/graemlins/thumb.gif
  8. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Do yourself a favor and get a compressor. A good one.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    junk yard ac compressor and brackets from Astrovan $14.95cdn (grab the pressure switch off the accumulator while you are there)
    new airtank from truck shop $43cdn (I bought 2 to replace my side saddle fueltanks as rocker protectors)
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    no no i was talking about a Adj. Reg. i dont think ill need one, i could just get one thats set at like, 100 psi or so and yes i am planning on a seprate system for the ARB, i also am planning on plumbing my whole truck, with a drop at every corner, should be pretty cool when i get done, thnaks alot for all the ideas /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Also im thinkin that i can mount the tank inbetween the frame rails sideways infront of the gas tank /forums/images/graemlins/peace.gif
  12. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    New 20lb Alum Tank - $90.00 Beverage Factory
    Fixed Regulator 170psi - $30.00 (Avail at most welding supply shops)
    You can get the hoses anywhere...
    My tank will fill my 35's faster than a a/c compressor conversion, plus it's portable and runs air tools /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
