CO2 tank mounting???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by az-k5, Jul 15, 2004.
  1. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    What are those of you with them using for mounts. I am looking for some kind of release mount like an extinguisher type but can't find any that aren't sold by offroad tank vendors (I don't like to pay convinience fees). Any input would be helpful.
    Also, is it safe to have the tank in the sun all day (mind you AZ wheeling is often +100°)? /forums/images/graemlins/ears.gif
  2. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Go to a welding suppy store. They offer several types of tank straps. That is what we use in the race trucks. Storrage and heat are not an issue.
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Wonder if I can mount this to the underbelly of my frame.....
  4. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    The tank needs to be upright or you will get liquid CO2 coming out (bad thing)
    Thanx
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I made my own, I used 3" angle then used 1" steel strap then I welded one piece to one side of the angle then wrapped it around the tank and made a little lip then I did the same to the other side and then to the bottom, I use 2 bolts with wing nuts to attach it around the tank. I will try to get some pics.
