CO2 Tire Fill Chart
Discussion in 'The Garage' started by DPI, Jul 11, 2003.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Some people were questioning how many tires a bottle of CO2 will fill.
    Here's the answer:
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Kewel /forums/images/graemlins/thumb.gif
    I should be picking up my 15lb bottle in the next day or two. Now need to get a regulator and gage /forums/images/graemlins/grin.gif
    Thanks for the info /forums/images/graemlins/thumb.gif
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Question for ya... How does Column "number of tires filled" relate to the 10-20, 10-25, or 10-35 psi column? For example, it takes more cubic feet to go from 10-20 psi than it does to go from 10-35 psi, given the same size tire... see what I mean?
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yep, I see what you mean. The graph does not tell you what pressure your filling each tire on the total number of tires filled portion of the chart. If I had to guess, I would say the filled pressure amount would be 35 psi, but that is just a guess. But is that from 0 or from 10 PSI. I don't know... Good point it doesn't look like the PSI portion relates to the number of tires filled! hmmm, I must do more digging to find that.
