Coarse Thread Bolts in Springs?
Discussion in 'The Garage' started by Hossbaby50, Aug 30, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    MuddyTazz and I were talking in PM's and he had a question that I am unsure of and want to know.
    Is it ok to use coarse thread bolts in leaf spring eyes? (with lockwashers and locknuts) I don't see why not but don't know for sure.
    It appears that my ORD greaseable bolts and my stock GM bolts are coarse but I am not 100% sure.
    Harley
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    all the suspension bolts in my k5 are coarse thread. AFAIK, fine thread bolts wouldn't be any stronger or more durable in this application, since the thread/nut is just there to keep the bolt in the hanger, not to withstand the forces of the vehicles weight etc. In an application like the studs that hold the passanger spring plate on a D60 though, being fine thread is the only way to go because the threads are the only thing holding the spring plate down, and more threads = more surface area = stronger.
    j
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    As near as I can tell the only reason to use a fine thread would be if you're worried about the nut backin off. Would take longer with fine threads than coarse. More rotations.
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    all are coarse thread from the factory, except for the front shackle bolts, which are fine thread. i dont see why it would make a bit of difference.
