Cobra 18 help
Discussion in 'Communication (CB | GPS | HAM)' started by thezentree, Oct 3, 2003.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    i have a cobra 18 thats goin to a 102" whip. i'm not getting more than 1/4 mile range at best when transmitting, and maybe 1 mile when recieving. i hooked it up to an SWF meter, and its 2:1 at under 2 watts. so from my understanding, the antenna length is OK, but the radio isn't putting out near the power it should. the radio is wired according to the manual (negative lead to negative battery terminal, and one positive to the +terminal on the battery, and the other positive to an auxilary circuit in the fuse panel). the fuses are all good. is there a ground problem? what have i done wrong? /forums/images/graemlins/1zhelp.gif
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Sorry it's taken so long for a reply... I must be slipping.
    It sounds like your antenna is fine. It you bought the radio used it might have been tuned for lower power output to drive an amplifier. If hasn't been tuned then you either have a band final output transistor or you need to have it tuned up.
    Try to find a cb shop locally and they should be able to turn it back up to normal for less than $30 at most places. If the transistor is shot they can probably replace it also for a little more.
  3. thezentree
    Sep 19, 2003
    7,198
    NC
    cool, thanks for the help
    i might get it tuned to 8 or 10 watts. is that too powerful?
    also, im thinking about selling it for a radio that has an RF gain knob and a PA function (yea, its fun yelling at people in the mall parking lot /forums/images/graemlins/ignore.gif)
