code 12
Discussion in 'The Garage' started by FatBoyBlazer, Jul 8, 2003.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    what does it mean...my truck at startup sounds like its got a big cam but it doesn't then i seems to runn normal with the check light on....can any body /forums/images/graemlins/1zhelp.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    code 12 is the normal code to have...you will always get that when you check codes..any trouble codes will come after that flashes 3 times.
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Poss the oxy sensor isn't working right till it earms up,making it run rich till then?Just a thought,some one here should have more ideas. /forums/images/graemlins/thumb.gif
  4. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    thats what it seems like i just put headers on it and had the o2 sensor welded in to the collector
  5. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Might have to get a heated O2 sensor...that should warm that sumbitch up to the 5 or 600 degrees it needs to be at real quick. /forums/images/graemlins/thumb.gif
    I got a Bosch one- supposed to be 'universal'. Has 3 wires. Black one-same as stock O2
    Two white ones- one ground, one tied in to be hot w/ the key on. I tapped a fuel pump wire, supposedly a lot of people do that.
    Just wait for a few more opinions before you go and spend the $60 /forums/images/graemlins/k5.gif
  6. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    im also getting a code 13 and 33
  7. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    aparently a 13 is the o2 and a 33 is a mass airflow..i just dosconected the battery for the night and i'll see if it runs better after a few days
  8. angrysnowplow
    Jan 8, 2002
    502
    MA
    Just found this post, was in Canada, Eh /forums/images/graemlins/thumb.gif
    I don't think you have a mass airflow sensor... /forums/images/graemlins/thinking.gif
    Did clearing the codes change anything?
  9. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Code 33 is for the MASS sensor if you have tpi, mpi, or efi. I am assuming you have tbi, in which case code 33 means MAP sensor. This is the manifold absolute pressure sensor. It is $27.99 at autozone.
    -Harrison
  10. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    what side do i disco the neg or pos? /forums/images/graemlins/1zhelp.gif
  11. angrysnowplow
    Jan 8, 2002
    502
    MA
    neg. should do it
  12. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    alrighty thanks
  13. dyeager535
    26,979
    Save yourself some hassle (radio presets for instance) and pull the ECM fuse. /forums/images/graemlins/laugh.gif
  14. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
