Code 42 and Rotton Egg Smell
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by btolenti, Dec 1, 2003.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Lately my blazer has had a erratic miss that happens every so often. I was driving it tonight, and the engine stumbled, the check engine light came on and the truck started running really lugged. It took more accelerator than usual to get it going, and it would stumble off idle. I checked codes awhen I got home and got a 12 and 42. Can a catalytic converter go bad and cause this code? Or did the pickup in the distributor go south, causing bad conmbustion and resulting in the odd smell?
    it's an 86 k-5 with a 350 (california emmissions...)
  2. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    rotten eggs = cat
  3. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    would that also cause a code 42????
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    rotten egg smell= fuel soaked cat
  5. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    i let the truck cool down for an hour or so and drove it around, and it seemed to be fine! I have no idea what to do next!
  6. My Suburban (89) kind of does the same thing. It was storing a code 42, but not now. Every once in a while the tranny feels like it downshifts and theres no power, then the check engine light flashes once, then no stored code. I still havent figured it out.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Your problems sound like one or both of two things.
    The code 42,stumbling missing ect under load+ CEL = Bad magnetic pick up coil. Cheap part but You have to pull the distributor to change it. Change the dist module while you have everything apart also.
    Rotten Egg smell is the cat. Try changing the pickup coil. If the smell is still there and performance is sluggish your cat is getting plugged.
    Fireinthehole
    If your CEL is coming on engine looses power momentairly but NO code is stored. It is usually the distributor module going bad can also be pickup coil too.
  8. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    my truck did the same thing, spent hundreds on diagnosis with no luck. every time i took it in the thing ran fine.dealer tried changing the EGR since it was getting bad, but it still came back. hasnt happened in awhile tho, i would agree with Thunder, its most likely in the dist. i started having problems after i changed the capNrotor. good luck
  9. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    after you replaced the cap and rotor?!??!?!?!?!?!? that's odd... I just replace my cap and rotor, and added MSD's super HEI kit too....hmmmmmmmmmmmmmm
  10. Not trying to hijack the thread, but, mine started acting up after I changed the plugs, plug wires, dist cap and rotor also.
    Mat
  11. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    not a problem.....looks like a lot of us have run into this...
