code 43 Electronic Spark Timing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by meanmudder, May 9, 2002.
  1. meanmudder
    meanmudder 1/2 ton status
    Feb 27, 2002
    128
    Cleveland, Texas zip 77327
    were is it at 95 chevy pu 350 ci
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I get the same code in my 89 k5, it comes on when it senses a knock in the engine, if the sensor is bad the sensor is down by the starter and its called the knock sensor, to see if the sensor works tap on the block with a scan tool and see if the engine sees a knock
    Hope that helps
  3. meanmudder
    Feb 27, 2002
    128
    knock sensor is good
