Code reading
Discussion in 'The Garage' started by chvyhs, Feb 3, 2005.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I picked up a S-10 Blazer for my younger brother and it stalls out at half throttle and the "Check Engine" light is on. I've heard that you can get a code by turning the ignition on a off a couple of times and the Engine light will blink, giving you a code. Can anyone help me with this?
  2. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    You need to hook up a reader to the ECM to get the codes.
  3. dyeager535
    26,982
    191
    Is it OBD1 or 2? If OBD1, all you need is a paperclip.
  4. kick
    kick 1/2 ton status
    Dec 19, 2002
    385
    FL
    S-10 stalls
    What year is the S-10 ?
  5. goldwing2000
    goldwing2000 Guest
    The on-off-on-off code thing only works for Chryslers.
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Not true.
  7. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Chrysler/Jeep/Dodge....True.
  8. jbs68
    jbs68 Registered Member
    Dec 20, 2004
    7
    Sacramento, CA
    does too...
    i have used a paper clip for my '87 blazer (obd-1)...true
  9. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    95% of GM OBDI will be able to use the paperclip trick.
    chrysler products can do the key thing and some OBDII (first year and rare).
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If its pre 96 ( OBD1 ) all you need is a paper clip and locate the ALDL connector under the dash by the steering collum. Here's how:Gm trouble codes
    If it is 96+ you need a OBD2 code scanner.
    Turning the ign on and off is a Chrysler/Dodge thing used to bring up obd 1 codes.
