Code Scanner
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Sep 7, 2000.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    Anyone use a code scanner? Are they worth it? I found one at an auto store for 30 bucks and another one at Napa (Kaleqip) for 100 bucks, are they all about the same or does Napa have a better model?
    5,000 Pounds of American Rolling Steel
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    You could save that cash and use a paper clip to check the code(grounds the comp and the flashes te codes throught the check engine light like the code scanners do).. I am not sure where you put the paper clip on the Blazers though. Also, since you wont have the code book, call one of your local parts stores and they usually will give you codes.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I have a Sunpro model, It was about 30 bucks, It isnt bad, it one works if the check engine light comes on. and then it will give you an idea of where to look at. It has worked out for me a couple time. I wouldnt pay much more than 30 for the one I have. Maybe the one for 100 is better i dont know. good luck
    BlazerBoy
    http://generalblueballs.coloradok5.com
  4. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    how do you use a scanner, and what does it do?
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    The scanner should plug in under the dash. Then you turn the key on and watch the check engine light flash. Its kinda like Morse code LOL. On my old 88 2wd pick-up I just used a jumper between two of the terminals. My service manual said which two to put the jumper on.
    Best part is the jumper costs about $2.00 to make.
    Rene
  6. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    The $30 code scanners work pretty well. They don't interpret anything, they just tell you what the computer says is wrong. There is also some freeware laptop scanning software that uses a $30 interface (if you don't make it yourself). Those will show you much, much more than a code scanner.
    I'd say go for it because sometimes figuring out the codes from the SES light is a b***h
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I bought a code scanner with the LCD read out it cost 180 bucks at Checker, and is worth every penny.It plugs into the under dash ECM scan plug.You can scan all componets and see if they are working properly Givs info on fuel ratio, volts, how your sensors are working and much more.Also tells you what codes are up and leads you in the direction of the failed componet.
    Get Out and VOTE!
  8. 89K5
    89K5 1/2 ton status
    Jun 14, 2000
    134
    Maryland, PA on Weekends
    Paid $30 from Eastwood.
    Paid for itself the first time I used it. Engine was hesitating, I tried a few things then finally broke down and bought the scanner. Got the EGR code, replaced it, problem solved.
    I figure I saved the $75 the shop would charge to just read the codes. A guy at work paid the Fo*d dealer $100 just to clear the codes (sucker), that didn't include the $75 to read it or labor to repair!
