  1. leadvillek5
    leadvillek5 Registered Member
    Nov 20, 2004
    85
    leadville colo
    findly got my k5 running and it has a code #42 and code #54. what could be steting these codes? the motor is .o40 bored 350. balanced, with 9.2-1 compression ratio, 487x gm heads , 1.50 exh ,1.94int, roller comp 258x, ported tbi and varible fuel pressure regulator. fuel pressure runs about 12psi at idle and crack the throttle and it goes up to 15psi. engine seems to run okay lots of power. i checked for a break in the electric spark timing (est) circuit #423 and it read .60 ohms. so the circuit is not open. i tried clearing the codes but they come right back. i think that i might need a new ecm computer chip. maybe from turbo city.anyone have any info on where to start?
  2. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    #42 is Electronic Spark Control Circuit. #54 is Fuel Pump Circuit (low voltage). Pm me and I will send a list of all your possible engine codes with possible causes and remedies.
  3. dyeager535
    26,980
    tristark5, does that include the troubleshooting flow charts?
    I've got those if leadville needs them.
  4. trikstark5
    Feb 17, 2004
    169
    usa
    Yes. It explains what the code is, the causes of the code and possible solutions.
  5. dyeager535
    26,980
    What I meant is, do they look like the one here
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    For your code #42 check the magnetic pick up coil in the Dist. Measure the risistance between the 2 wires coming off it. Should be 500-1500 ohms. if out of specs it may be going bad. Check all connections and grounds for Spark timing circut and ECM.
    For the #54 Check all connections/grounds from the back to the fuel pump. they can get corroded and show low voltage to the ECM
