  1. sorryofficer
    sorryofficer Registered Member
    Jun 23, 2002
    18
    arizona
    i have a 1987 jimmy fullsize 350 and i need help with codes...i got the 12 and then 24 43 44 codes and then the 12 so i need help with what the middles ones mean. I know that they are in the Haynes manual but i dont have one. Thanks
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    24 is the vehichle speed sensor-check the connections at the ECM, and the TPS setting
    43 is the ESC-check wires from the knock sensor to the ESC, wires from the ESC to ECM, and/or replace the knock sensor and/or the ESC module (i had this code was the knock sensor)
    44 is lean exhaust- check the ECM wiring connections terminals, have fuel pressure checked, check the oxygen sensor wire, check the carb or TBI gasket, vacuum hoses, and intake manifold gaskets. And/Or replace the oxygen sensor.
