Coil in cap/ MSD
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86K5TrailBlazer, Nov 24, 2001.
  1. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    I want to upgrade my ignition system. So I went out a bought a MSD6A Box, I know I need to upgrade the coil, so i picked up an accel super coil. Do i just remove the coil in the cap, bypass it, did i get the wrong stuff? What do I need. Its an 86 Blazer 350
    <P ID="edit"><FONT class="small">Edited by 86K5TrailBlazer on 11/24/01 03:53 PM.</FONT></P>
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Re: Coil in cap
    I have the Super Coil for my HEI...it replaced the factory coil on top of the cap. Did you get one for the correct year? 87 was FI and had a different style distributor...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. high&liftedup
    high&liftedup Registered Member
    Nov 14, 2001
    64
    CA
    Re: Coil in cap
    Larry, I have recently gone through mix &amp; match of ignition parts and I would recommend that you stick with MSD parts. I recenlty put a MSD offroad box on with a 1 year old Accel dist.... I went through so many issues and found out yesterday that the Accel dist. had some much play in the shaft that the rotor would move up and wipe out the cap. The MSD coil works well and I believe in compatibility. Right now, Im not a fan of Accel.....
    HE will always get you out of the mire clay!!!
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Re: Coil in cap
    I'll agree with that assessment of Accel products...junk mostly! I already had the super coil and to be honest it's the only Accel product that has worked for more than a week or so...so I kept it.
    Rene
  5. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    Re: Coil in cap
    im not too big on accel stuff either but ive been running a new accel hei for a couple years now and its been great.. its more or less a stock replacement.. runs good though
    mike
  6. 86K5TrailBlazer
    Apr 24, 2001
    436
    Orange,CA
    Re: Coil in cap
    thanks for the quick responses, I was going to do it this morning but now thats its raining Ill put it off and get the MSD coil and return this Accel coil. I remeber tRustyK5 you also had some issues with thier wires. Also the coil looked universal. Actually I also have an Accel coil in the cap. ;( from PO. Do I remove the coil on top of the cap and wire it (distributor) to my new coil. Also in the manual it mentioned some sorta harnerss for a 4-Pin Module, whats is this and do i need it?
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Re: Coil in cap
    Get that harness! It just makes things easier. With that, all you do is plug things in, instead of splicing everything.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  8. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Re: Coil in cap
    As Blazer Boy said GET IT! The harness that is. [​IMG]
    I have an 83 with the mix and match set of Accel coil and MSD 6A. I have not had a problem till now.
    The whole system is getting messed up. If I where you I would look into getting a new Modual for your unit. I believe that MSD makes one but if not get a replacement one form NAPA or AC Delco. I'm starting to wonder if it was worth putting in the MSD....
    just my .02 PM Philly87 he works for MSD. and is a realy cool guy. He even called me at work....
    Late KEN
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  9. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: Coil in cap
    MSD IS AWSOME. I run it in my race car and swear by it. I need it to burn the race gas and the nitrous. When you do an MSD ignition buy everything MSD, much better that way. You can get rid of that 4 pin module and wire the box direst, thats what I did. The get the correct MSD coil that goes on top of you HEI dist., get MSD wires and you will be set.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  10. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Re: Coil in cap
    Ya I'm thinking about it, but also looking at the wallet and I only seeing receipts. No cash[​IMG]
    In a matter of time I will. but in the mean time I need to figure out the dang code 34....
    any ideas?
    KEN
  11. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    remove the coil, replace it. and, you bypass the module itself (which is underneath the dist. cap), it's farily straight forward.
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    <a target="_blank" href=http://sosaman.home.texas.net/carpics.html>http://sosaman.home.texas.net/carpics.html</a>
