Coil spring conversion progress pictures
Discussion in 'Vendor Forum' started by balterbuilt, Jul 26, 2006.
  1. balterbuilt
    balterbuilt 1/2 ton status
    May 10, 2004
    385
    Santa Rosa
    here is some floor mock up pictures, still need to make some brackets for the track bar and rod ends
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    how much lift?
  3. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    how much you want? It's adjustable up to around 15"
  4. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    thats badass
    how much is the final going to go for ?
  5. chosen(1)
    chosen(1) 1/2 ton status
    Nov 19, 2002
    206
    Michigan
    Track Bar? Why not triangulate and eliminate it?
  6. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    simplicity and lower cost to the customer. No final price as of right now, but i think it will be hovering about 1300.00. I started tearing down the truck today but due to lack of motivation (and a hangover) i didn't get far :doah:
  7. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    sitting on coils now, yee haw:D
    I used to work for a bank stacking dimes professionally
  8. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Looking good, can't wait to see some flex pics. What are those springs out of?
  9. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    a jeep...hahahahaha. But no seriously they are out of the front of a jeep wrangler rubi. perfect for a blazer with a lgiht rearend. For the big boys with the big tires etc. I might be offering a heavy duty kit with some 2" tube larger heims, and stiffer springs.
  10. TRAILTOYZ
    TRAILTOYZ 1/2 ton status
    May 21, 2005
    106
    Wasilla, AK
    Sweet looking innovation there. You should add a couple simple tabs for limit straps. Think you'll need a track bar to eliminate side to side movement?
  11. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Does that track bar bolt up to the stock spring location?
  12. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    yeah there is going to be a panhard rod, just haven't had time to build it yet. The links mount to the stock front springs hnager ,but you have to cut the rivets off and move it forward about 18" because the links are 4' long. Limiting straps will probably be needed. Not sure if the 'ol rubi jeep srpings will be stiff enough, but i will enjoy the overly soft ride for a while just for a change from the way too stiff springs! Ugh, i can't wait for the floating feeling.
    I think this kit will be adaptable to the front axle (with heavier springs) but i'm going to keep leafs up front for dependability. I think with all the issues involved around doing link front it's not worth it, just use some 52, or 57's out of a dodge for super flexyness.
  13. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    alrighty, made a little progress today... got the links done, decided to change the design from the super beefy way I was going to do it to a more high clearance design. Should be stout enough...that's what testings for!
    also started making the panhard bar mounts on the frame. Tomorrow if i have time I will make the panhard bar mount on hte axle then make the panhard bar. The drivers side should go together in no time once all that's done...right :blink:
    sorry bout the blurry picture :crazy:
  14. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    any updated pic? the old ones dont show anymore
  15. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    unfortunatly i have been delayed from waiting for parts but here are some pics of the axle bridges and upper link, might have it done begining of next week or over the weekend....
  16. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    flexed it out today. Only thing that kept it from articulating was the ground. I couldn't make it bind up, seems to have lots of travel got about 20" verticle until the axle hit the ground. We'll see what it gets with the shocks and springs on it.
  17. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    think this would work with a set of 14" Travel coilovers?
  18. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    yes definetly
  19. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    well how much longer till this is ready for production and how much $$$$. I'm needing a rear setup for my truck.
  20. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    :Dnot sure still need to take her out and beat it fro a bit....oh get your minds out of the gutter...:D
