Coil spring questions.
Discussion in 'The Garage' started by timmay, Jan 8, 2005.
  1. timmay
    timmay Registered Member
    Oct 24, 2004
    62
    Here
    If I take the spring from an ink pen and try to compress it with my fingers, it rockets across the room. What keeps lifted coil springs from bowing out in the middle and collapsing? Is there a limit to how tall a coil spring can be? What about 24" tall?
    Thanks.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    When you get to the point of needing long springs the only way to go would be 'coil over'. I've seen some long std type springs and some times they look like they're about to do the biro spring trick. (wouldn't want to get in the way of that!!)
    Rubicon Express seem to use fairly long ones on their J#*ps
