coil wire ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Mar 30, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    there are 4 wires coming out of the top of my coil 89 tbi 350, 2 red and 2 white, one of the whites has a connector on the end, and does not go anywhere,, what is this wire for???
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The factory tach. The wires for most "options" are in all the wiring harnesses. That way GM only has to stock one wiring harness part number to fit all the trucks. If the option isn't installed, then the connector just goes to nowhere. [​IMG]
    Look at the harness that goes to the tail lights. It's bundled and tie wrapped underneath the truck, because the same wiring harness also fits short and longbed pickups. [​IMG] GM's the king of finding multiple uses for the same parts!
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    harryh3 is right it is the factory tach wire
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  4. 87K54WD
    87K54WD 1/2 ton status
    Mar 23, 2000
    105
    Texas
    I was wondering about this too. So, could I hook-up an aftermarket tach to it without cutting up the GM wire harness? Also, I've noticed that I have an orange single wire near the fire wall. It can come out all the way to the TBI unit. What is this wire for. Seems like I was told before that it was for lighting the tach. Is that right?
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, most tachs can hook right to it. Check the directions though, as some tachs will tell you to hook them up differently. Don't know what that orange wire is for. You might need to look that one up in the shop manual wiring diagrams.
  6. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    my truck has the huge fuel gauge next to the speedo, could i get a factory tach from a junck yard truck, and just install it, and if so, where would the fuel gauge go. i had the dash out already to repair the little cable for the shifter pointer on the column, so i do not think that would be to hard.
