Cold running engine!?
Discussion in 'The Garage' started by skratch, Dec 22, 2003.
  1. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Ok so it's in my 94 G20, but I have no clue what is wrong. I have a new thermostat (180 I think) and she won't break about 120 degrees.
    It's a TBI 350 with a factory radiator, fan . . . nothing has been changed but the thermostat and coolant. I know most vans typically run a little hot, but this thing runs way cold, can hardly get any heat out of the thing if your on the freeway.
    Any ideas on why it's acting like this would be really helpful, thanks. /forums/images/graemlins/1zhelp.gif
  2. dyeager535
    26,982
    191
    Any chance the van uses a heater valve, and it's just not opening?
    Barring that, have you hooked up a scanner to check what the ECM is seeing?
    If the heat coming out of the vents isn't hot, then it's likely the engine truly is cold, (and not a gauge/sender issue) but with a coolant valve, that could be the problem.
  3. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    Never thought of that, I'll have to take a look, thanks!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's also possible that the new thermostat is letting coolant leak past. It doesn't take much flow at all to keep the engine cool when it's really cold out. BTW, the spec for that engine should call for a 195 degree thermostat. That will pump out lots-o-heat! /forums/images/graemlins/cool.gif
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Funny you should bring this up. Just tonight I was working on our new K5. It would not get over about 110-120. Pulled out the tstat, found it was a 160 and apparently opening too soon. Put in a spec 195 tstat and it's setting about 200 on the gauge, not bad at all and it runs better (probably the first time it's gone closed loop in a while /forums/images/graemlins/eek.gif )
    But, still no heat (and it isn’t really cold here). My next thoughts were heater flow valve in the line is stuck/unhooked, or the plenum door diaphragm is stuck/unhooked. Looked under the hood again, no valve. /forums/images/graemlins/thinking.gif Check the hot water lines and the one from the engine is somewhat hot, the return from the heater core is COLD. /forums/images/graemlins/eek.gif I don't mean warm, but COLD. Only thing I can think of now is a plugged heater core... /forums/images/graemlins/rolleyes.gif
  6. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    Hmm, I get some heat so I think the heater core is fine, I'll yank it all apart and get a new thermostat for it. Hopefully that will help.
    Thanks! /forums/images/graemlins/thumb.gif
