Cold Start?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Nov 10, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok I havent driven my truck in a week it has been sitting outside of my shop in the cold winter weather. And now I cant get it to start it isnt getting any gas it is a stock 305 with a stock qjet. Any suggestions?
    1985 GMC JIMMY
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Remove the fuel line to the carb and hold it over a can and have someone crank it and see if it is pumping fuel.
    If it doesn't then the pump has gone south.
    If it is then change the filter. it is on the carb.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. buzzk5
    buzzk5 Registered Member
    Aug 30, 2001
    29
    gimli,mb,ca
    how cold??? up here we get ice crystals in cheap gas often enuf...i dump methanol
    in if i get questionable fuel....only has to be below freezin , to cause you greif
    is it old gas?
    Dave
    80K5 on ice
    are they all spinning?????
  4. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    No the gas is about a week or two old it has been sitting outside the shop for about a week now and it has been about 25 degrees
    1985 GMC JIMMY
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Check for moisture in the distributor cap. That could be a very likely culprit.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>See my pics here</a>
  6. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Gas line anti freeze.
    If you are having too much fun it's probably illegal.
  7. dyeager535
    26,980
    Pour a decent amount of gas into the carb, in the hole JUST in front of where the air cleaner stud goes. (q-jet) You're problem is that more than likely, the well plugs int eh carb leak, and after sitting for awhile, the float bowl is empty, as well as the fuel line from the tank. Adding fuel to the carb will let the engine run long enough to pull fuel from the tank, and get it into the carb. My truck runs fine if I start it every day, but if I let it sit for a week or so (car too as a matter of fact) I have to crank and crank for it to start. Or dump gas in it.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  8. bking
    bking 1/2 ton status
    Jan 4, 2001
    176
    Alaska /Here from Ireland in Dec 2000
    Hi, I'm in Anchorage, moved here in 1998 from Ireland. My wife who is from Alaska, quickly informed me of the winter do's and don't regarding my K5, and successful cold weather starting.
    I installed a new heavy duty battery, I always use gasline 'HEET' NEVER EVER leave your gas tank with a low fuel level. Also, I plug my block heater in basically all winter. Temps here this last week or two have been dipping to 6 or 7 F at night, and way lower with the windchill. I also fitted a $50 remote start I got at Walmart.
    Now, a few weeks back, I had the no start problem, I removed the dist cap, took it inside, cleaned it good and dried it with a hairdryer, did the trick.
  9. bking
    Jan 4, 2001
    176
  10. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    So I should pour some gas where the choke is then? or the holes closer to the firewall?
    1985 GMC JIMMY
  11. dyeager535
    26,980
    The "slot" just behind the primary venturis (choke blade) Its between the primaries and the stud for the air cleaner.
