color of spark
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jun 5, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I just put an HEI in my 73 and got a tune up kit with new everything for it and new wires. I put it in and i was wondering what color the spark should be, im getting an orange one. Shouldnt it be blue? my plugs are gapped properly and im pretty sure i hooked it up to a 12v source(male terminal on fuse block marked IGN.) Would not using the proper gauge of wire cause this because in mot sure of the exact gauge but i know its not 12-16. any help would be great
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Wire gauge shouldn't affect your spark. Is everything new, and if not, did you replace the HEI module?
    I'm so poor I can't even pay attention [​IMG]
  3. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Hmmm. You might try screwing with the timing a little, and try running your power from a different terminal.
