Color of wire...
Discussion in 'The Garage' started by unclematty, Jul 25, 2004.
  1. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I can't find a wireing diagram for my 83 blazer. what color is the wire for the reverseswitch on the transI think it's green( it's the only one left). I'm almost done rewireing this thing (without a diagram????) just can't remember what color the reverse switch wire is. thanx in advance /forums/images/graemlins/waytogo.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Try here /forums/images/graemlins/thumb.gif
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    green/light green wire pair is GM
  4. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    time to hit up the alldata subscription, no luck on anything else. /forums/images/graemlins/rolleyes.gif
  5. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    alldata is down for some reason. Can anyone show me the complete circut for the reverse switch, from the firewall, where the lite green wire comes out. to where the dark green wire goes into the firewall, somewhere in the middle is the backup lights, and the reverse switch. it just isn't making any sense right now /forums/images/graemlins/whistling.gif
  6. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Dont they all go to the neutral safty/back up switch on the column right above the brake pedal?? the Purple ones are the neutral safty circuit and the greens are the back up, right?? Or am i just really tired and not thinking straight?
  7. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    I need a complete circut diagram of the reverse switch, (for the manual trans)some body go look at yours and tell me where the two green wires come from and go to.Thanx M /forums/images/graemlins/whistling.gif
  8. dyeager535
    26,979
    On the trans they plug into the drivers side, up near the very top. REAL PITA to connect if it's in the vehicle already. (newer ones use a much better locking connector) Hope that is the "where do they go to" question you wanted answered.
    IIRC that wiring has a connector inline that joins the cab wiring to it, but I don't think I can see any of that on mine, it's all taped up in loom.
